PLEASE Help Installing new Stanley back door
In process of installing of a new Stanley back door. Have installed doors before. This one is really sticking at the bottom of the door as you go to close it. Have adjusted sill to lowest point and still sticks. Door has been nailed in and appears to be level when checking with a long level. Clearance on top of door is fine. Any suggestions on how to improve the clearance on the bottom of the door?
Door also does not appear to be completely flush at bottom when closed. Please HELP!!!!
I have seen this alot
I have seen this a lot on newer doors, especially on double/french doors (most of them were installed by professionals). Is this intentional to get a tighter seal on the bottom? Or a result of poor installation? Or a manufacturing defects?
How do you solve this problem? If the door is square and evenly gaped, is there a way to move the door up or the sill down?
Thanks,
abkent
Thanks,
abkent
Fixed
Here is how I fixed the problem with my Stanley door. I carefully removed the trim on the threshold and sunk some screws into the floor. This pulled the threshold down and increased the clearance on the bottom of the doors.
Good luck,
abkent
Good luck,
abkent
