Garage Side entry doors
Fire rated doors are very common. I would probably go about it in a different manner. I would go to the store looking to purchase another door. Don't say anything about the doors you already have. Tell them what you want to look at. They will be glad to show you if they think they can make a sale. Usually doors are not packaged in a box, only a wrapper and the whole door can be viewed easily. My question is are you sure it is a only a 20 minute rating ? Usually it is a 60 minute door, but every area is different. Good Luck
Fire rated doors are available with lables and without. I'm not sure why their avialable both ways. Commercial applications usually require the label to be on the unit. It might be simply be cosmetics and convenience. A commercial inspector can inspect a building much quicker with everything (sticker)labeled as a house a residential inspector may take the time to look at paperwork or even take your word for it. Check the catalogue number with the manufacturer and ask the inspector if a lable is required to be riveted or attached to the unit.
