Trim for interior doors won't fit.
I am updating the trim on my interior doors. One problem I see as I am starting, is that the new trim (2 1/2") won't fit around all sides of some of the doors. Is there a standard way to trim with this issue? Do I just cut the trim and leave it a little narrower on the one side?
thanks in advance,
John
thanks in advance,
John
Sorry I wasn't clear. My old door trims were 1.5", and in some cases, that is at the edge of the wall and there is no way a 2.5" trim will fit. should I trim the 2.5" trim down to 1.5" on those couple of instances where the trim absolutely won't fit?
I have already been using the same 2.5" for window and other doors, so changing back to 1.5" won't work!
Thanks
John
Thanks
John
