Oversized screw hole in window frame
I had to drill out screws to replace an opening device for my window. As a result I have no threads in the window frame for the new screws and the holes are oversized. I can't just use a bolt on the other side because the device comes right up against the frame. Is there any way that I can get screws to hold in the holes now without having to replace the entire frame. That would be a big job because the frame is sort of embedded in the wall.
I gather you are talking about a casement window, either aluminum or steel framed. You just need to tap the hole for a larger screw (may have to drill the hole slightly larger first). Casement windows use an 8-32 screw to hold the operator in place. Tap the holes to either 10-32 or 10-24, whichever you can find the 1/2" screws and the tap for.
