sliding cavity door removal
I need a little assistance...I will be tiling my kitchen floor and it looks like the added heigth will interfear with the sliding cavity door that ajoins another room. Is there a trick to removing the door to either change it or modify it, or do I need to go through the wall?
Received 1 Upvote
1 Post
Remove the casing and trim around the pocket door, and pull it out.
You should not have to go through the wall.
If you're adding a layer of tile under iits slide area, youmay have to trim the bottom off while you have it out, however.
Good Luck!
Mike
Good Luck!
Mike
