Vinyl Replacement Windows
I am considering replacing all the windows on the first floor of my house (50's bungalow, original windows/storms). My question is this: Are the vinyl replacement windows you can pick up at Home Depot/Lowes meant to fit inside the existing framing? I think I remember reading that somewhere before. If that is the case, is the rough opening size simply the size of the inside of the box? When installing the unit, do you then just flash over the old flashing?
Thanks.
Thanks.
All-righty-ditey.......you got the most simple kind to do...the kind replacements were really designed for.....
How To Measure for Replacement Windows
Wood Double Hung Version
Wood double hung windows are what vinyl replacement windows were “really” designed to replace, though they definitely can and are used in other situations.
The thickness of a replacement window frame is 3 ¼”, which is the combined thickness of 2 standard wood sashes. The replacement window goes in the space where the old wood sashes slide up and down.
In windows that date from the late 50’s forward, wood window makers used fairly standard sizes and construction methods. Standard sizes start around 18”, then go to 20”, then 24”, 28”, 32”,36”, 40” and occasionally you see a 44 or 48” on WIDTHS.
The sashes will generally slide up and down in an aluminum or plastic track.
Heights usually run 38”, 54”, 62”, 72”.
For example: a wood window called a 2/0 x 3/2 is a 24” wide by 38” tall window.
IMPORTANT: Window sizes are always given width first, height second. Don’t get that mixed up !
When you measure the width, you would get REAL close to 24” when you measure inside the area where the sash slides up and down. The height will measure about 37 ¾”or so, measured from the top of inside sash track to the TOP of the sloped part of the sill where the sash makes contact when it is lowered.
So for that window, I would order a replacement 23 ¾” wide and 37 ½” tall.
I order my windows “EXACT SIZE”…..if you don’t tell them that, they will automatically cut your measurements ¾” or more……..on the assumption it’s easier to fill in than tear out, I guess…..If you do what I tell you, there is just enough gap to slide the unit in and leave a caulk joint…..otherwise, you have some serious insulation stuffing to do, plus more trim problems later. GET EXACT SIZE.
On older double hungs, like the type that have rope pulleys and sash weights back in the wall, you measure the same way, but the sizes will vary quite a bit more…..they were far less standard……they sometimes vary ½” or more even between window to window that appear the same size.
I'll give ya some install info in another post...
andy
andy
