Replace strip at bottom of Steel Door
Can the strip on the bottom of a steel door be replaced. My door is in good shape except for the strip at the bottom and I'm losing my cool air through there.
Should have a replaceable weatherstrip. Can be a bear to work on because you can't really see what you are doing. Easiest way is to take door off hinges so you have full access to the door bottom. If for some reason the strip is not replaceable, there are add-on strips that can be mounted to the door to do the job.
