Extra long tension rod?
I'm needing help. I have a window that's 94" wide by 36" long. There is a small top overhang where I could attach a curtain rod and I intend to. But I would also like to hang some shear curtains below the topper and would like to use a tension rod. Is there a possibility that the make them in this width?
i don't think so, but you can get really tiny (like 1/4") rods with small brackets that you could use (inside mount). you'll probably need a center support, too, even with a tiny rod & really lightweight sheers - gravity alone will probably make that rod sag a little & then your curtains will droop.
72" - 120" tension rod
If you do want to go with the extra long tension rod in spite of potential sag, I found one here, after looking for a long, long time!
http://www.countrycurtains.com/jump....code=SEARCHDEX
They are also sold on Amazon:
http://www.amazon.com/exec/obidos/tg...45712?v=glance
for $39.
for $39.
Thanks for posting the link to extra long tension curtain rode. It was not easy to find. The URL apparently have changed ... i found the one below, seams to be the same as posted previously... also for $39.
Curtain Rods Flat Spring Tension Rod - Country Curtains®
