Can I reverse the side my drapes pull from
Bought a home with center draw drapes that the chord pulls on the left side.
Can I change this to pull on the right side?
thanks
thanks
Hi and welcome to the forum! Read this reply and see if it helps:
http://forum.doityourself.com/blinds...raw-cords.html
You should be able to pull the cord through and there should be some type of 'locking' device or lip on the other control slide. I just did it with mine - switched from right draw to left draw. You might be able to find directions from the manufacturer online.
