measuring to install traverse rod & separate valance rod
In order to have to valance cover the traverse rod are they placed at the same height or is the valance above the traverse?
Hi and welcome to the forum! You can mount the valance rod or board pretty much anywhere, even with the traverse rod or higher. Really depends on the height of the wall, the style and length of the valance. There's no rules. You can adjust up or down as necessary. The important thing is to make sure it projects out 2" more than the traverse rod for clearance and it should be a little wider than the traverse rod.
