New Duct in Converted Garage
I was told that 8" duct was to large for a 17' x 11' room because it would not have sufficient velocity to cool the room. Would a 12' run of 8" split into a 4' & 8' run of 6" duct maintain velocity while cooling the room better than a single 6" duct? Any help would be greatly appreciated.
Thanks,
Erik
Thanks,
Erik
Received 1 Upvote
1 Post
Its more in what is the heat loss and gain for this room. Not just how big is it, windows, outside door,insulation? Where are the registers at and how far do they have to throw the air . Now Ill say this most of the time a 12"round will go to two 8" round and one 8" round is good for two 6" round pipe to registers Also what kind of return do you have for this room
It all counts for what to put in
ED
ED
Thanks for the fast reply. There aren't any windows or outside doors. The room is fully insulated, walls and ceiling. There is one register located in the ceiling above the seating area (it's a home theater) centered on the 11' wall 4' from the wall with the door. I was thinking about putting another register above the other half of the room. As far as return I only have the crack under the door now but was thinking about installing a return through the wall above the door. The house is located in Phoenix, AZ if that makes a difference. Thanks again.
Erik
Erik
