Electronic Air Cleaner Problems
I just bought a house in which a old Sears Electronic Air Cleaner is installed. I have very little experience with these devices, and with the amount of dust in my house, I am not even sure if it is working. My friend had one and I seem to remember it zapping quite often where as mine only zapped after I washed it, and then only for a couple minutes Are there any tests I can do to see if it is working, or is there anywhere I can get a manual on it?
Thanks
Thanks
ED
I am with Ed on this..
Turn off the EAC and pull the cells.. You can find media filters that will fit most unit.. Your's maybe 20 by 25 by 4"... If so, then you can go to a home center like Home Depot and get the media filter.
Received 0 Votes
Electronic Air Cleaner Circuit Board Needed
I have an old Sears brand electronic air cleaner that is attached to the furnace. It stopped working and I discovered the problem is a bad circuit board. 2.5 inch x 2.5 inch square. Part No. 859-0253 DY-11; If anyone knows where I can get this board please reply. Sears does not have it.
Received 0 Votes
Information For Warcards
Pleated filter - Dahhh... The correct answer is Air Flow Switch Board. You can find a replacement for that circuit board at: www.ontimemall.com Hope this is helpful!
Received 0 Votes
I have the same old Sears air cleaner and am looking for that same part 859-0253. Went to the web site Mike 9001 recommended but couldn't find it based on the part number. Any suggestions. And did the part replacement work.
Thanks for any help.
5rudbergs
5rudbergs
