Range hood damper problem
Old 06-28-05, 08:59 AM
Dwight Harley
The damper in my exterior vented range hood bangs open and shut on windy days. The builder is giving me the run around so I suppose I will find someone to fix it or fix it myself. Is the problem from turbulence at the roof vent?(The damper is in the hood, not in the roof vent) Should I try another type of vent?
Old 06-30-05, 09:58 AM
Andrew's Avatar
Received 14 Votes on 10 Posts
Two things to check...
Be sure the damper at the hood has the small rubber "bumper" intact, that helps quiet the clatter. Also, make sure the damper at the roof jack is closing. It sounds like it might be stuck open.
