water leaking in/around the ducts
Old 07-17-05, 06:12 AM
not_very_handy
water is dripping in my drop ceiling, and when i check where the water came from i saw its coming coming from the ducts..i not sure if its inside or outside the ducts..how can i fix this?
Old 07-17-05, 08:40 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
water drip
The water is caused by the cold air in the duct meeting the humid air surrounding the duct. Insulate around the duct as much as possible using foil faced, fiberglass duct wrap. This presumes the duct to be metal.
Old 07-17-05, 01:30 PM
not_very_handy
is the cold air meeting the humid as you've said,will caused water that much?i forgot to mention to you that the water drips..like the water drops every seconds...and it happened while its raining hard that night but i do your advice anyway..thanks..
Old 07-17-05, 03:00 PM
Grady's Avatar
Water drips
If your A/C is roof mounted, water could be coming in around where the equipment is attached to the roof. Another possibility is a clogged drain or rusted out drain pan.
Old 07-19-05, 10:44 PM
not_very_handy
ty
ty!!! grady you dont know how much your advice help me! take care
