Air Return Project
Hello, here's 2 self explanatory photo's of adding a return air for the livingroom which has 2 heat supply 6".
Is it ok to use 6" metal pipe for the return? run is 20 ft.
Reason for adding return is weak air flow from the supplies in the livingroom,
will this project help?
Air Return Project Photos
Thanks again
Thanks again
Yes, you can tap into that area that you've pointed out for return..
Question for you...
How big is that return grill in the hall way??
Is that the only return you got now?? (I hope not.)
Also, what's that pipe coming from that all taped up?? (Not good!)
________
I take it home with out a basement? So the ductwork is under a slab?
if so, the duct maybe rusted out, and has closed off from over the years with dirt?
Question for you...
________
The return for the hall way, are they on top of each other? if yes, almost would want to say you are not getting enough arei going back into the furance..
So go ahead and add another return..
Is this water heater short?? or furnace just happend to be pretty tall??
I don't like the tape.. Why are they there?
The only room that wasn't part of the ranch that was added after the whole heating system is the living room and is has a good distance to go to get some return air .
So I'll let you know about the progress.
Decide im gonna go with 9" metal pipe with a damper installed about 4' from the furnaces trunk.
thanks much for your pointers Jay
The tape was there when I bought the home 10 years ago I wonder a bit to about that ... but I thought maybe extra protection for the seems.
