Adding heat to a basement with drop ceilings
Received 0 Votes
I own a tri-level home which results in a partial basement. The basement is partially finished, needing only heat and flooring other than concrete.
I know from reading other posts that I can tap into my main trunk from the top and drop the heat from the ceiling. The problem is the ceiling is of the drop variety. Am I correct to think the next possible area to place my vent is a little ways down on the wall? If so, how far down, if not what are my options?
Side question is do I need a return line since this is in the basement?
By the way, The room I want to vent has two exterior walls one with a window. Not sure if this is useless info, but thought it may help with the replies.
Thanks for helping me out.
Received 0 Votes
Agreed. It shouldn't difficult to add a supply in the drop ceiling.
If you want your basement to be a liveable environment, then adding a cold air return is mandatory. This will help balance the air temperature by remove the cold air from the floor.
Received 0 Votes
You are right it is a suspending ceiling. I just wasn't sure if it was normal practice to place the register in a ceiling tile. It seems it would make it difficult to work around in the future.
I guess that concern isn't as big as I thought it was.
Thanks for the replies
Received 0 Votes
Are there any exceptions to this rule? I moved into a 19 year old, split-entry home last August. The basement is half garage and half game room/laundry/hall/bathroom. The hall has a ceiling HVAC vent; the gameroom has two ceiling HVAC vents; and the bathroom has a ceiling HVAC vent. Until I read your comment, I never thought about the cold air returns........there are none in the basement.
Any thoughts on this?
Received 0 Votes
In the basement, supply vents should be placed on the ceiling and cold air returns are placed near the floor and away from the supply vents.
With this set-up, the cold air returns not only draw the cold air off the floor, but also help to draw the warm air down to the floor level. This is what helps to achieve a balanced temperature.
If all vents (supply and return) are on the ceiling, or if you don't have any cold air returns, then you will never get the cold off the floor.
Received 0 Votes
Received 0 Votes
Originally Posted by XS6DFG0
There is no doubt that the temp. in the basement is much cooler than the first floor - I guess this is why. I could probably install one in the game room (25' X 12') - I wonder if that would be sufficient?
