Electric Air Cleaner problems
I have a Trion Trim TX. The Green and Red LED lights go out after turning the power switch to on after about ten seconds, but it zaps dirt in those ten seconds so I think its working. What gives? I cleaned the cells and the pre-filter. I just read a forum about these EAC failing often and being more trouble than the replacable filters. Can I install a replacable filter in my EAC? It has a slot for an optional charcoal filter, could I place one there and turn the EAC power off? Or should I fix the EAC and use both a filter and the EAC at the same time? Any info would be greatly appreciated?
