Best Return Height
Old 04-30-06, 12:16 PM
P
Best Return Height
Is there a general guideline for what height a cold air return should be located off the floor? I have an 8' ceiling in the bedroom I'm finishing, and I am not sure what height to put the register. Thanks!
Old 04-30-06, 01:09 PM
F
Received 39 Upvotes on 31 Posts
Is this for a heating-only, cooling-only or combined system?
Since hot air rises the preferred position of supply is low and returns high; for cooling it is the opposite. Combined systems are a compromise and designed towards the function most used.
Old 05-01-06, 04:25 AM
E
In an ideal world, it is best to have two returns on the upper floors which you can open/close depending on whether you are heating or cooling.
During the cooling season, you would open the high return.
During the heating season, you would open the low return.
