Bathroom vent - Dryer Hose?
Old 05-22-06, 07:07 AM
C
I need to vent my bathroom fan, currently goes into the attic. I saw at HD that have the dryer vent kits with the flexible aluminum, can I use that?
Old 05-22-06, 11:34 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
hi
you need an insulated cover over the pipe to stop condensation i9f not it will form condensation and drip inside the vent
Old 05-23-06, 04:18 AM
C
So can I use that type or should I use the solid - rigid venting aluminum pipe?
Old 05-23-06, 08:09 AM
W
Received 26 Upvotes on 21 Posts
I don't see any problem using dryer vent. You can also get an even cheaper flexible plastic vent. The important thing is to wrap the vent line with insulation to minimze condensation. This is especially important if you live in cold climes and if there is a fairly long run of duct.
Old 05-23-06, 08:37 AM
C
Doesn't mold build up in plastic?
Old 05-23-06, 10:02 AM
W
I don't know about mold. I have a Nutone heater/vent fan in a BR used daily. The vent hose is plastic, it came with the vent. Most house vent piping is plastic (PVC) and I don't think mold is a problem there. It's several years old and we haven't noticed anything that would indicate a mold problem.
Old 05-23-06, 11:42 AM
Your fan will move more air (and mositure) and do a better job with the smooth, rigid aluminum than with a flexible pipe.
Dick
Old 05-24-06, 05:11 AM
E
Flexible duct should be illegal. Whenever possible use solid pipe.
