Sticking bathroom fan advice?
Received 0 Votes
My Nautilus N688 50CFM exhaust fan is sticking when power is applied. I get a buzzing without fan movement for a few seconds and then the fan starts moving. I cannot find any oil holse, but I have applied oil (Tri-Flow) where the shaft enters non-rotating portions of the motor. This has made the fan turn more freely. I am worried that this may be a very short-term fix.
The fan and plate is newer than the fixture. I replaced this portion about 8 years ago when it failed. The fixture in in the ceiling between floors and would be a bear to replace.
Is there a better way to lubricate this fan motor?
Am I being naive trying to lubricate it?
Is there a better replacement for the fan blade/motor/holder that would work in the same fixture?
Thanks for any help.
Hello Joe!
I have the same exact fan, and have found the best ultimate solution is to replace the motor. With that said, it's not hard to recondition the existing motor. Remove the mounting plate from the fan. Next, use an air hose and blow all the lint and gunk from the motor. Next, GENTLY and EVENLY pull the blower wheel off. Using a nutdriver, remove the through-bolts from the motor, and remove the motor from the mounting plate. Remove the two remaining nuts on the motor, and remove the rotor. Using a q-tip soaked in WD-40, clean out the bronze bushings, the spacers (small washers on shaft), and the rotor shaft itself. Next, oil the felt wicking around the bushings and the bushings themselves using SAE 20 oil. I use the plastic "Zoom-Spout" oil from the hardware store. Lastly, reassemble the motor, mount it to the plate, and carefully install the blower wheel. Reinstall & you're "Good To Go"
Received 0 Votes
Thanks Andy,
When you replaced the motor did you just get another Nautilis fan and use that motor or did you find something better? If something else, what did you find?
Joe
Joe
