whole House Fan - tips to quiet?
Old 08-21-06, 05:27 PM
I have purchased a 24" direct drive fan from Home Depot but have now been told that this is a very noisy fan (I realize most whole house fans are noisy) and when we looked at it, it seems to operate by a pull chain.
Is there:
1) any way to make the fan quieter when we install it?
2) any way to change the on/off mechanism from a pull chain to a wall switch? Or do I need to take this back and get a another type of fan?
My house is 900 sqft and I do not have AC.
Thanks!
Old 08-21-06, 05:42 PM
nap's Avatar
nap
New Member
Received 1 Vote on 1 Post
Both things can be accomplished to some extent but it would be better to just buy a fan that fits the requirements you have.
Old 08-21-06, 08:16 PM
F
Received 36 Votes on 28 Posts
A direct-drive fan will almost always be noisier than a belt-driven fan. For the same air moving capacity a slow-turning belt driven fan will be larger and quieter than a direct-driven fan. A belt-driven fan will probably last much longer than a direct-drive fan.
Yes, you can install a wall switch, timer or thermostat on the fan you purchased. It will require a small bit of wiring exterenal to the fan.
