thin duct?
Old 08-28-06, 01:24 PM
A
thin duct?
I was wondering if there is such a thing as a thin duct? I am hoping to finnish my basement that has a low ceiling and the issue is that there is a full size duct running the length of the room thus causing the occasional head bump but more importantly I would like to close the exposed ceiling with drywall. Can anyone help me on suggestions?
Old 08-28-06, 03:11 PM
T
There are insulated flexible ducts available and may be an option. Check with local building inspector re: codes and permits. Codes vary from area to area. I believe there are codes re: finished ceiling height in basements and changes in ductwork.
Old 08-28-06, 04:07 PM
Ed Imeduc's Avatar
Wink
Stop and think about it. Yes some time we go down to a 6" deep duct in the basement. But you have to keep the same sq " in this new duct.Then they get so wide that the metal goes bang a lot when the blower comes on. Like said is there a code there . Have ran 5/8 drywall tight to it. If span is not to big. Best is a drop ceiling that takes about 3/4" under the duct.
ED
