Heat Recovery Ventilator problem
Old 10-11-06, 11:27 AM
D
I have a "LifeBreath" HRV. seems as though the low voltage wall mounted humidistat was shorted out, and now the unit will not work.
the short did not cause a trip in power at the panel, and when I connect the power the power lght on the unit does not illuminate, however, there is a slight humming sound.
I popped the panel cover to the electrical controls of the HRV, and there is no obvious fuse / ircut breaker. A local HVAC tech told me to look for a circut breaker on the transformer, but there is nothing there.
I have disconnected the remote (wall mount) Humidistat as there is an on board humidistat as well - on the same part of the unit as the power LEDs. Still no dice.
Thoughts?
Here is a pic (assuming I can post pics here)
or link to the pic here:
http://i25.photobucket.com/albums/c92/CabbyShack/DSC02272.jpg
Old 10-11-06, 02:49 PM
Jay11J's Avatar
My parents got this unit as well, and I haven't really look in this unit to see how it's set up.
You removed the low voltage wire, and take a reading at the screws where the wires go to?
What is the model number is yours? I will see if I can find something.
Old 10-13-06, 03:42 AM
D
no voltage on the humidistat leads.
model NO 200max... or is it max200....
Old 10-13-06, 04:22 AM
Jay11J's Avatar
I looked at the manual, and only shows some parts breakdown. Looks like there is a fuse in side the unit, I honestly don't know where this is at since I never been inside of this unit. I am guessing behind the control knobs. so check to see if the fuse is blown or not.
