How Wire Heat Pump to H/Well Thermostat ?
Old 10-28-06, 02:47 PM
I'm considering wiring a Honeywell programmable thermostat to my ~18 year old Lennox Air-to-Air Heatpump (it has auxilary electric-furnace heat).
The Wiring on the old Thermo doesn't match the Letter-coding on the new programmable (of course !)
Can anyone help out here ? The OLD Honeywell Thermostat wires are listed as follows:
Top-left: R,Y
Left-to-Right: X, F, V/VR, E, L (V/VR jumped together)
Top-right: M,A
New Honeywell Programmable Thermostat:
RC / R, O/B, Y, G, C, L, E, Aux
I know a programmable won't save me much money on a Heat Pump type system, but I want to upgrade the old slider system (and have the unit allow for cooler temps when sleeping at night).
Any advice -- greatly appreciated !
Thanks,
Matthew
Old 10-28-06, 03:04 PM
Ed Imeduc's Avatar
Received 1 Vote on 1 Post
Wink
On a heat pump we try to tell people to set it and let it alone. You dont say how old it is can be HP6 on up to a HP 19
On the lennox X is common V/VR is power That F is fan. We have had some honeywell tstats that we have called them on and they cant say how to wire them.
ED
Old 10-29-06, 05:14 AM
Unhappy
Thank you Ed,
The Heat Pump is either a HP10 or HP11 (5-Ton) on an EC-10 forced-air electric furnace... the T-Stat is a T874 (Honeywell).
The new Honeywell instructions indicate terminal connections as follows:
New T-Stat Possible Wire (Old system)
RC --> Rc or R
R --> R or V or VR (RC/R are jumped)
O/B --> O or H or B (no wires on H-Pump !)
Y --> Y or Y1 or M
G --> G or F
C --> C or X or B
L --> L or F
E --> E or X or X2
Aux --> Aux or W or W1 or W2
There are no O, H, or B wires on my old system so its a bit of a mystery which wire should go to O/B on the new T-stat.
I have a feeling this may not be a do-able project but will give it one more try if anyone has info !
Thanks,
Matthew
Old 10-30-06, 04:13 PM
Ed Imeduc's Avatar
Wink
Id say ring this out for sure Cause I dont recall on this unit. My paper work on the HP10
X is common Hot is V/VR Now R is the switch over to cool that is O or B L is malfunction
Old 10-30-06, 07:59 PM
talked to an oldtimer at work today about this HP10.
He said, old new
M - Y
X - C
R - O
VR - R
E - W1
F - G
L - L
Not sure about A, and Y
Top-left: R,Y
Top-right: M,A
Old 10-30-06, 08:29 PM
Ed Imeduc's Avatar
Wink
Still at a loss here
you say lennox HP10 heatpump.You had to have a wire on O/B
The heatpump has been runing in the winter ok???? Does the electric heat come on some and in defrost?
ED
Old 10-31-06, 07:18 AM
Many Thanks Guys:
See if this makes sense to you:
I'm told that "R" is the Reversing Valve and connects to O/B on the new T-Stat
Was also told that "Y" is Aux-Heat on the old and should be connected to the new T-Stat, "Aux"
Lastly, was also told the "A" on the old T-stat is for "Anticipator" and that this is no longer used.
This information came from an HVAC Board similar to this one (though not as good !), so I don't know how reliable it is.
We just bought the house this summer (I'm in Canada) and its working great in the cool temps - I expect we may need Aux-heat support in December / January but will wait to see. We budgeted to replace the HP with a natural gas system when we purchased the home, however, the old homeowner had the system rebuilt last year, so we'll use it as long as she lasts.
Thanks,
Matthew
Old 11-01-06, 10:25 AM
Ed Imeduc's Avatar
Wink
Go to http://warmair.net You can compare fuel cost for where you live.
ED
