Bathroom returns
Bathroom returns
I have a walkin closet next to my master bath and wanted to add a return to the closet. Theres only heat to the closet and if I don't let the furnace fan run constantly it gets cold in the closet,so I figured a return would help the problem.The nearest return is in the master bedroom which is located on the other side of the bathroom,is this a good idea?
Received 1 Upvote
1 Post
Dont know the duct lay out you have there. but sounds like a lot of work for the cold air return. Id try and just let the closet door open a little as see how that works Any dampers in the pipes that you could close down a little to get more air out of that register?
