Moving ac register
Moving ac register
Air handeling unit is in the attic and would like to move a register in the kitchen (1st floor) from the top of a wall to the bottom (through the toe-kick under a cabinet). Will I loose much efficiency with this change?
Thanks!
I'll be adding about 7 feet to the straight run. The current layout has on 90 degree turn and the new layout will also have one 90 degree turn. I was more worried about ac fed to bottom of room vs. top of room.
Received 1 Upvote
1 Post
Dont worry about high or low there. With the duct in the attic . Later on if need be you could go into the duct up there and put what we call a robber in it to help get more air in that pipe.
