Which of these 4 plenum take-off examples is best? (illustration incl.)
Old 01-26-07, 02:22 AM
Goodman AEPF18301 Variable Speed Air Handler (w/GSH130301 13-seer 2.5ton Heat Pump)
1200 sqft single story home in Los Angeles
Mounted on a table/platform up in the Attic floor & Positioned horizontally
Hello friends. I'm trying to decide which of these 4 methods is best for the takeoff on my new air handler.
Please take a look at the mickey-mouse diagrams I drew (link below) and give me yur thoughts if you can.
http://www.rawlsenterprises.com/plenum-takeoff-examples.jpg
P.S.
The factory airway opening cut out at the top this air handler is 17-1/2" wide x 11" deep. What size plenum would you build for your take-off choice?
Old 01-26-07, 04:56 AM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Id have an HVAC company do a duct layout for you after they did a heat load on the home.
Old 01-26-07, 05:31 AM
R
It would all depend on the required duct sizes and the space that is available for duct. As stated a heat load then a designed system for your house.
I always prefered as much trunk (to keep flow and pressure) equal.
Old 01-26-07, 08:47 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Id say why all the Y's .Id do a trunk line and tap off that.
2.5 ton= 1000 cfm, for a good job you need about 175sq" off the unit.
Old 01-26-07, 09:49 AM
Airman, I am having an HVAC company do the job/layout but it doesn't mean they know what they're doing. I refuse to "take their word for it", and because I can't go to his prior customers and inspect their houses to make sure he's doing the job right I must "trust" his judgement. However, I know there are many HACK shaddy tree HVAC companies out there who will just slap up some flex duck, run it any which-a-kinda-way and call it a day with their hand out holding a big fat bill. So, like any good and concerned homeowner should be, I do not want my installation to be a candidate for the "wall of shame" over at hvac-talk.com. Therefore I come to the internet to see what good people like you and Ed Imeduc has to say about what I am about to experience.
Because of Ed......I left the first installer who never did a load calc, manual J or manual D on my house. He just said "Oh, I know these houses and you'll need a 3.5ton." and was about to charge me an arm & leg. After Ed's reply on another question here, I began questioning him and he couldn't answer saying this and that was not neccessary. I said thanks but no thanks and moved on. Now I found a reputable company, but I'm sending him through the ringer as well.
Old 01-26-07, 10:52 AM
ED,
I questioned all the Wye's too. But the installer says coming off the end of the plenum would be better for airflow CFM. He suggested option #3, but I think option #4 is best for static pressure without much loss in CFM.
I can't do a trunk line based on the design of my attic. What do you suggest I have him do?
Old 01-26-07, 02:58 PM
You should never have a runoff off the end cap of the main duct! I to quested the pics. Ed said it wright make sure you have some main trunk before the takeoffs.
