Cold Room
Old 01-31-07, 08:20 AM
O
Cold Room
I have one room in my house that is always colder then the others. I have tried closing part way some of the registers in the other rooms to see if that helps force more warm air into the cold room. No luck. What can/should be done to help fix this problem? The house is a 9 years old, single story and this room has always been cold. There are 2 rooms farthest away from the furnace, one stays nice and warm, however this one stays freezing. The registers are in the ceiling. The house has a Trane XL heat pump outside w/ furnace in the garage.
Thanks for your help.
Old 01-31-07, 09:27 AM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Is the duct work connected in the attic!
Old 01-31-07, 09:42 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Like said if you can get to the duct there check it and see that it is ok. No sharp bends in it. could also see if you can put whats called a robber in the duct to get more air to that run.
Old 01-31-07, 04:45 PM
O
I checked the duct work, seems fine, there is air coming out at the register, however it is cold, (not very warm at all). I checked the register in the room right across from this one and you can feel a difference in the temp of whats coming out of it and whats coming from the cold room register.
Whats a robber?
Old 01-31-07, 08:08 PM
Ed Imeduc's Avatar
Wink
Whats a robber?
Its like a small metal scoop you put on the take off and it sticks out in the duct some.
