Adding Zones To an HVAC System
Received 0 Votes
I live in a 2 year old home in the Northeast. The house is 3100 sf with a single thermostat controlling the HVAC system. Although I have gotten a better handle on controlling the temperature in the house, we still feel distinct variations (1st floor vs 2nd).
I have seen climate control systems that add multiple zones to the existing
system. The idea being that efficiency can be significantly improved by only heating or cooling when necessary (ie. when occupants are present) and by only heating/cooling to the exact desired temperature.
Has anyone ever installed one of these? Do they perform as claimed or should I be looking for another solution?
Thanks.
Thanks.
Unless carefully engineered and installed, zoning of residential forced air systems usually create more problems than it solves. You probably could benefit from a careful BALANCING of your system along with running the blower on low speed continuously. Thermostat relocation or multiple temperature sensors averaging through the thermostat might also be of help.
Like said forget zone control in a home. To run the blower 24/7 helps. Also if you have a return up and down. close off some of the up return when on heat. then close off some down when on AC. A up and down return will help a lot here. On any 2story homes we put in 2 system one for up and one for down. If you want them to work good.
Received 0 Votes
Seems as though everyone agrees that this isn't the way to go. The real problem lies with the Master Bedroom. It doesn't warm up like the rest of the house. I had thought about a booster fan to push more air but I haven't seen positive postings for those either!
Some questions based on earlier responses:
What can I expect adding another unit to cost? Is this even an option? As I said, right now I have a 3100sf home with a 5 ton unit.
Thanks for bearing with the questions. I'm HVAC impaired!
[Like said forget zone control in a home. To run the blower 24/7 helps.]
Dosn't this put alot of stress on the unit? What increase in cost can I expect?
[Also if you have a return up and down. close off some of the up return when on heat. then close off some down when on AC. A up and down return will help a lot here.]
Can you explain this a bit more. Since I don't quite understand, I'm not sure if I have this.
[On any 2story homes we put in 2 system one for up and one for down. If you want them to work good].
