Spacing ducts on plenum
Are there any guidelines for spreading out ducts on the surfae of the plenum? I currently have a 6", a 6" and two 6" ducts coming from each of 3 sides of the plenum (with the return blocking access to the 4th side) and also a supply vent directly on one of those sides to warm the basement.
I want to change one of those 6's into a 10", and the two that are together into 8" each. My concern is that most of the ducts will be coming from one corner of the plenum. Will this hurt my airflow? Here's an overhead sketch of what I want to do, if that helps:
---________|+6"+|___
___|++++++++++++++|
++10"+++++++++++++|
___++++++++++++++|
---|_|+8"++|_|++8"+|_|
___|++++++++++++++|
++10"+++++++++++++|
___++++++++++++++|
Last edited by dclark8822; 10-16-07 at 06:34 AM. Reason: spaces on drawing didnt work
If a 10" delivers enough for 4 6", maybe I want to use an 8" instead? I want less heat upstairs than downstairs.
My biggest concern is that most of the ductwork leaves the plenum in one corner, and I hope this won't rob too much pressure.
