Is it safe to use aluminum tape on flexible air duct?
Old 08-26-08, 01:25 PM
C
Hello,
Due to a water incident in my house, the outside and inside liner of a flexible air duct was slashed open (about 1 to 2 inches) to check for dampness. Since it was found to be dry, is it safe to use Intertape aluminum foil tape (ASTM E84 Rated) to seal/tape this cut (both inside liner and outside liner)? or do I need to replace the entire flexible air duct?
Thanks in advance for any suggestions.
Old 08-30-08, 11:34 AM
Jarredsdad's Avatar
That should work. Might also see about getting a small tub of airseal duct mastic to put over it patch. While you have the mastic out, it would be a good idea to check all connections and mastic them also.
Old 08-30-08, 07:21 PM
C
Jarredsdad thank you for your response. I appreciate it.
Old 08-30-08, 09:17 PM
Air Conditioning Help
Make sure to put hangers on both sides of your patch to take any pressure off the duct because a tear in flex duct with any pressure on it will continue to seperate
Old 08-31-08, 06:57 AM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Flex duct is so cheap and easy to install Id replace it.
Old 09-05-08, 10:46 PM
C
Thanks Mike N and Airman.1994. I appreciate everyone's suggestions.
