Connecting rigid ducting to bathroom exhaust fan
Old 09-06-08, 04:29 PM
Wasn't sure if this is the right place to ask this. I'm installing an exhaust fan and using rigid 4" ducting. The ducting has a tapered end, which I assumed goes into the ducting pre-attached to the outside vent, but I don't know how to secure the non-tapered end to the fan itself, as both the ducting and the connection on the fan are 4" exactly, I can't fit one inside the other. How is this supposed to be done, is there a coupler of some kind that I need?
Old 09-11-08, 09:46 AM
C
Received 7 Upvotes on 7 Posts
You may be able to find some coupler to do that, but the cheap way is cut one of the end open (cut straight in a inch around the edge every half inch distance) so you can fit the other end in their losely, and than use duct tape to tape it tight.
Old 09-11-08, 10:15 AM
Gunguy45's Avatar
Super Moderator
Metal duct tape, not the regular cloth stuff. Actually, since it's rigid, you could probably butt them together and put 2 wraps of tape around them and never worry about it.
Remember with ducting, just like shingles, you want a smooth flow, so each pipe should go over the one before it in the line of flow.
