Install dryer duct booster or find a shorter vent route?
Received 0 Votes
We have a dryer vent that runs in our basement and then leading outside of our home 30 ft. Our brand new dryer still runs way too long.
Should I find a shorter vent route by moving the vent outlet location? If I do this I can cut it down to 15 ft.
Total cost $30-$50
or should I buy a dryer duct booster like this one?
Total cost $275
Tjernlund Products, Inc. - Tjernlund Residential Capacity Dryer Duct Booster® (LB1, DE160)
Total cost $30-$50
Total cost $275
Received 0 Votes
the perfect finish DV328AEW - Dryers - Washers & Dryers | SAMSUNG
Received 0 Votes
here is a link to my dryer, where can I find what the dryer says?
Received 0 Votes
See the table on page 8 here.
Received 0 Votes
Could be something other than exhaust venting - have you tried running one load with the exhaust vent disconnected and a window open to see if drying time is improved?
Received 0 Votes
I did and the drying time did improve.
Received 0 Votes
"We have a dryer vent that runs in our basement and then leading outside of our home 30 ft." --------- I have to ask: no pipe runs are outside, right?
Booster fans are no longer legal on dryers-- M1502.6
Be safe, Gary
Be safe, Gary
Received 0 Votes
no pipe runs outside correct. So you are saying in Milwaukee, WI booster fans are no longer legal? Where did you get that info?
Received 0 Votes
Yes i have one of those brushes that attach to a cordless drill ans goes deep inside. Works great.
Received 0 Votes
Gary,
Does the change prohibit the use of booster fans (for example to improve the performance of an otherwise compliant system), or just remove the exception allowing their use to extend the length of exhaust lines?
BTW, re booster fans, see the video at:
Tjernlund Retail Store—Dryer Duct Booster (Model LB1), 5 Year No-Clog Guarantee
I can't vouch for the test, but it did make me question the design of the Fan-Tech product.
Received 0 Votes
A contractor came over today and told me to install a metal filtration box downstaira. place a dehumidifier down there in the summer time. Since we're in WI our winters are cold.
S&P Accessories - Metal Filtration Box For Excessive Dust Environments by S&P | kitchensource.com
HVACQuick - S&P MFL Filter Boxes
this is my best bet. re-routing the duct venting means I still have 15 ft of vent. booster fan with a 30 ft vent duct won't help.
Received 0 Votes
Received 0 Votes
he has 25 yrs experience he says. is there any type of filter that can withstand the air/moisture from the dryer?
#21
Received 0 Votes
Sorry I didn't quote my County- not to be used for longer length:
M1502.6 Duct Length- Maximum length of a clothes dryer exhaust duct is
limited to 25 ft
• No longer an exception allowing booster fans to be installed for longer
lengths
• New exception: Where large radius 45 degree and 90 degree bends are
installed, determination of the equivalent length of clothes dryer exhaust
duct for each bend is permitted (in accordance with ASHRAE engineering
standards) From: page #11-- http://www.co.pierce.wa.us/xml/servi...bulletin51.pdf
Now this is interesting: gas or electric length, page 2 in the new code: http://www.dpis.com/News/2008_11.pdf
Be safe, Gary
limited to 25 ft
lengths
Be safe, Gary
#22
#25
Received 0 Votes
Received 0 Votes
The city building inspector and an master hvac contractor who also does furnaces told us that with all of the bends we have close to 100 feet of dryer vent ducting. WOW
Here is what they told me.
"We can get your dryer problem resolved by shortening the run and increasing the pipe from a 4” to a 6”. The new dryer vent would be by the bush next to your air conditioning unit. The total cost would be $334."
Is this cost reasonable?
#27
Received 0 Votes
I just spoke to the guy who installed our radon mitigation system in our home and here is what he says. He still thinks a booster fan is the way to go.
Ok.... the fans I use daily are about the same specs as the ones advertised, so... I'll connect one of our fans on the outside of your house for a couple weeks. You'll have to plug it in when you run your drier, but it will simulate having one of these fans on the end of your current ducting. I can produce about 75 CFM using 3" pipe... about 95 CFM using 4" which you have.
My bet is that using one of these fans cuts the dry time by 2/3'ds and your temp to low, which helps the clothes "life". If it works, you can call these guys and tell them they're full of crap. If it doesn't, you can tell me the same thing. My bet is I win if it's even close to the 2600 radon systems we have running right now.
The question to me is how "open" the drier is to allow me to pull air... but I don't think that will be an issue if I can achieve what they've designed in maximum flow.... which will maximize energy efficiency. The cost comes in sucking conditioned air out of the house, but that's the way any drier's designed. The alternative is hanging your clothes out in the yard.
#28
Received 0 Votes
Make sure it's not blowing dryer lint onto the condensing units coil...
#29
Received 0 Votes
correct, it is far enough and it's going to positioned in a way that it will blow the lint, if any, far from the unit.
plus there is a huge rose bush between the unit and where the exhaust duct will be.
