Combine 2 ducts into one
Old 11-21-10, 01:13 AM
Planning on finishing a basement and am trying to save space so I only have to frame 1 ductwork instead of 2(and of course to save the space!). Is it advisable to combine the 2 ducts in the picture below into one? I've already moved the duct closest to the wall about 4 inches closer to the wall(think installers did a bad job). I'm thinking of getting a Y or T joint and daisy chain the 2nd duct from the wall into the 1st one. They're 2 different sizes as you can probably tell; I think on is 8" and the other 10".
Wish there's a way to post them here instead of externally through a url, but here's pictures of the ductwork(:
a's Site - Ductwork that needs combining/relocation
Was thinking of using something like this:
Saddle Tap Tee Wyes: American HVAC Parts
or:
combined with a 45 or 95 degree adjustable.
Thanks in advance for any replies/suggestions.
Old 11-21-10, 06:24 AM
airman.1994's Avatar
Received 4 Votes on 4 Posts
Best practice is to use two ducts! If you were to use one duct you would still have to increase the size of the one line.
Old 12-03-10, 08:54 AM
The longer duct line(bigger in diameter) in picture 1 goes to the master bedroom on the 2nd floor, but we already have 2 ducts going into the room from the same side. Most of the time I close one of the vents anyway to keep the heat from running too much - only have 1 zone. So, I'm not really concerned about restricting airflow to this. Am being stubborn here I know. What do you think?
