need tight 90 off side of plenum
Old 10-29-11, 06:59 AM
C
im adding a zone for my basement. to do this I am comming off of the side of the plenum. I purchased a broadway 90 and starter collar thinking this would work but its adding 6 inches. I need to make a 90 off the side of the plenum how would I go about doing this?
Thanks
Old 10-29-11, 07:10 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Dove tail the 90 and forget the starting collar. Might be hard to get a damper in it but can be done.
Old 10-29-11, 07:34 AM
C
not worried about damper as there will be a zone damper a tad down stream where I have room
do you have a picture of how to dove tail the 90?
Thanks
Old 10-29-11, 11:58 AM
Zone damper on a branch line? This sounds like a unit killer.
Old 10-29-11, 12:02 PM
Duct Take-Off Collars. Here is a pic
Old 10-29-11, 01:14 PM
F
Received 35 Votes on 27 Posts
Dovetail means to come off the main at an angle rather than at 90 degrees. It requires an elliptical hole in the plenum and the "starting piece" will have to be field cut and tabbed to fit. Not a difficult job for a skilled sheet-metal worker but definitely not easy for a beginner.
Old 10-29-11, 02:46 PM
C
zoning system with bypass
Old 10-29-11, 02:50 PM
C
i was talking to someone in the hvac field and they told me to cut the hole and inch shorter than my additional trunk line. then the remaing inch will be used as a flap and just slide the broadway fitting in. does this sound right?
Old 10-29-11, 03:52 PM
F
I don't know what a "broadway" fitting is. I CAN do the dovetail but I can't explain HOW to do it.
Old 10-29-11, 04:42 PM
C
second fitting on the below page is what I have.
http://www.graymetalsouth.com/cat043pg.html#122sd
Old 10-29-11, 11:27 PM
F
I can't explain how to do it. I suggest that you go to the public library and find some older books on sheet-metal work. Audel's Guides are good. They will explain in detail and with pictures how to cut the hole, flange it and install the S clips and drive cleats. It isn't rocket science but it does take some know-how AND some specialized hand tools.
