can i use top of plenum?
Old 11-17-11, 12:49 AM
K
Question can i use top of plenum?
hi folks, i'm kib...
i'm glad to be aboard and appreciate any help from the pros. my question is; my wife wants a 10'x20' office in the garage. can i use the very top of the plenum to connect flex duct? it's the only place on the plenum with enough space to comfortably cut a 6" or 8" hole. the plenum is in the attic and i am in fl. if that helps thx! kib
Old 11-17-11, 03:43 AM
W
Received 51 Votes on 46 Posts
Question
Is this an air conditioning question?
Old 11-17-11, 07:43 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
You can! But Id say not the best place to tie into. Make sure you use a DAMPER!!!!
Old 11-17-11, 08:25 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Remember also...if the garage will still be used as a garage, you will probably have fire codes you'll need to deal with. Even more so if the office is attached to the living area of the house.
