Re: Flex Duct Vs. Metal/Insulated
Old 12-23-11, 05:52 PM
E
In the crawl space I have an old unit with metal duct with two bents or so on each pipe, many of them were loose and leaking heat last winter, and I investigated only after a 700$ gas bill for Jan. houchhhh
Should I install flex or insulate current old metal ducts???????
How do you calculate pressure and static pressure in a home???
Tnks
Old 12-23-11, 06:29 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Metal duct is far better than flex. I'd seal and insulate what you have. I'm not sure what you mean by calulating preside in a home. Only way to do this is with a blower door test but really u don't need the figure. All u need is what needs to be fixed.
Old 12-23-11, 06:45 PM
E
Thumbs up
sound good!
what would be a good pipe insulator?
Old 12-23-11, 08:08 PM
R6 duct wrap stapled and taped.
Old 12-26-11, 06:12 AM
Received 98 Votes on 86 Posts
I'd seal the leaks with foil tape first, then insulate.
Old 12-29-11, 01:17 PM
U
That flex duct sucks! At least under trailers. It gets ripped by animals trying to get warm, etc.!
