ducts in attic ?
Received 0 Votes
ducts in attic ?
is it a bad idea to run ducts in the attic, even if they are well insulated ?
Received 0 Votes
When doing research on unvented attics at buildingscience.com, they indicated that moving the insulation barrier from the floor of the attic to the roof deck made a significant difference in energy use for homes that had ductwork in the attic space. Based on the information I read there, I would avoid ductwork in the attic if possible. If it isn't possible, be sure you air seal all the connections and insulate them as best as possible. I don't think R-6 is enough. If you plan on adding blown insulation to your attic, bury the ductwork.
Received 0 Votes
someone told me it was bad. so i am following up on that.
my problem : my new house is pretty old. the furnace is newer. but it looks like they used the original (?) ducts. and certainly the original vents and returns. it seems to me that the placements of these are outdated. the ducts are run in the (cold 50deg) basement. vents/ducts in the floors.
i was thinking about making 1 central return, about in the middle of the 1 story house. and then running new ducts up to the attic, and new vents at the top'ish of a wall in each room. my condo had this, and it worked extremely well.
Received 0 Votes
no comment on my idea ?
i guess the main reason to run them in the attic is to get them out of the low ceiling basement(future man cave). but if there is a good basement solution = i am all ears.
and if i did run them in the attic, i would put much more "blown in" than i am planning thus far. to cover the ducts.
