Air return in basement
Old 07-05-12, 06:35 PM
D
My basement is freezing . My house is a two story and the upstairs is warm even though it is getting good air flow. I noticed that there is no air return in the basement and it is like a freezer down there. Would a air return down there fix it as it would draw the air in and push it to the rest of the house....help
Old 07-06-12, 06:11 AM
Received 1,273 Upvotes on 1,213 Posts
Welcome to the forums. I moved your question into its own thread to increase visibility.
Do you have vents in the basement?
Old 07-17-12, 08:52 AM
A
Based on my personal experience, another possibility is that you may have a leaky vent connection off the main, dumping cold air into the basement.
Grab a flashlight and check all branches in the basement to see if there is a loose connection. Once found, apply some mastic to seal it off
Old 08-15-12, 06:55 AM
P
Drings13,
You will need to supply more information to get an answer. Does the basement have heat supply vents, is there any return air vents, is there a makeup outside air duct going into the basement, is the basement finished and insulated or unfinished concrete?
