Combining ducts or Not
Old 08-05-12, 08:25 AM
D
If limited space on plenum and wanting to give each area a supply vent, whats your thought on combining supply ducts to say 2 adjacent areas like: Kitchen and Breakfast? (This open area, about 204 square feet, currently has only 1 supply vent.)
Provide a single supply duct of 8 inches, providing about 230 CFM for the total area. Knowing that this could be noisy, split into 2 supply vents, 1 over each window in each area, fed by individual 6" ducts from the 8". In theory giving each area 50% of the volume delivered by the 8".
or if supply plenum space allows
Would you rather run individual supply lines to each: Kitchen (104 sq feet) 7" providing 160 CFM (allowing for appliance heat gain) and Breakfast area 100 sq feet getting 6" 110 CFM.
Thoughts?
Old 08-06-12, 07:24 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Always go with separate lines.
Old 08-06-12, 07:32 PM
D
Thanks for the response, appreciate it
Old 08-11-12, 05:57 AM
P
If your plenum space is limited, your proposal is a sound one. I have used that application many times with good success. Try to keep the 6" runs as equal in length as possible and build a triangular distribution box at the 8" duct end to attach the two 6" runs to.
Old 08-11-12, 06:42 AM
D
Thanks for the additional advice.
