Calculation of temperature control in enclosures
Old 10-09-12, 10:36 AM
U
I try to calculate a temperature control in enclosure by methodic below.
http://www.axisindia.in/pdf/axis-ste...emperature.pdf
How to calculate heat transfer coefficient k [W/m K] of enclosure material like: 1. polypropylene (thermal conductivity 0.11 [W/m K]) and aluminum composite (thermal conductivity ~ 0.3 [W/m K]) ?
Thank you
Old 10-09-12, 12:07 PM
B
Received 47 Upvotes on 43 Posts
Hi uniuu, and welcome to the forum,
One of the weaknesses we have here in the states is not being comfortable with the metric terms, especially with old folks like myself. I have to convert everything to btu's, F�, and ft�. So forgive me if I'm a little slow catching up with your question.
If I understand your question, you have a box made out of aluminum and insulated with a layer of polypropylene. I believe the (W/m K) is actually (W/m� K), the (�) symbol is often omitted. In any case, to add those thermal coefficients (we call them U-factor) you would invert each and add the results and then invert your answer. This would give you a single thermal factor to apply to the entire area of the box.
Does that help? I can study the units a bit more to be sure if needed.
Bud
