floor vent boot that has a filter and dirt trap?
Received 0 Votes
do they make a floor vent boot that has a filter and dirt trap for the return end and out end just having a dirt trap to keep dirt out of the ducting? if you know of any please send a product link.
Few returns are in the floor, although it happens. Do you have a picture of your set up so we can see what you are talking about? http://www.doityourself.com/forum/el...your-post.html
Received 0 Votes
i currently do not have the system installed. this will be a new system installation that will use hydronic forced air and will be zoned. so i do not have the pics. still in the planning stages.
If you are in the planning stages... First thing I would do is to HIRE a pro. If a HVAC system is not installed properly you will be very disappointed with how it heats or cools. A filter rack should be installed in the return ducting. I would use a 4" filter rack.
Received 0 Votes
i did find an hvac contractor who will work with me on this and will do the work in fragments but i still am trying to find a vent boot with trap. if not ill have the guy install speediboot with those under the register filters.
Received 0 Votes
here is the link to the hydro duct fan coil that i will most likely be using. cutting at the bottom of the studs to run up a wall return vent worry's me since i fear it weakening the house structure.
http://www.turbonicsinc.com/HYDRO-DUCT-APPLICATIONS.pdf
