Modifying Fan in existing housing to increase CFM
Received 0 Votes
Hi,
I rent an apartment that will only provide a 50 CFM fan for a bathroom that requires 70 CFM for area and another 30 CFM for static duct air.
The fan is installed in an 8" housing that fits the Nutone universal replacement 50 CFM motor and fan. The fan itself is a white plastic disc with 90° blades that face down into the bathroom.
Is it possible to install a new fan motor and improved blade system?
Thanks
Thanks
Hi rich,
The other approach would be to increase the run time. They make switches with a delayed off cycle to allow a bath exhaust to continue for an adjustable period of time.
The other argument would be to measure the actual flow of what you have and request a fan to meet their stated 50CFM.
Bud
Bud
Received 0 Votes
No Timer involved
The fan is on a basic on/off switch
The landlord already came a replaced the fan, I'm willing to dump a couple of bucks to put the right fan in.... and take it when I leave and put their's back.
Rich
Rich
Then, why do you want the larger fan? Typically they are necessary to exhaust the moisture or smells from that area. And typically, just running them with an on/off switch is not sufficient. That is when the timer is added, to allow longer runs without walking away and leaving the fan running.
Just an option, not an argument.
Bud
Bud
Received 0 Votes
Hi Bud,
I really think the fan can't even overcome the static air in the duct work. I can spray air freshener, leave the room with the fan on and door closed for an hour and still smell it. When I take a shower, the mirrors fog to the point of dripping.
No argument intended in the last post, but length of time doesn't matter in this case. I need more power ;-)
Rich
Rich
I'm wondering if the exhaust damper is partially or fully stuck shut. Another problem could be a crushed or obstructed exhaust duct, or a clogged outside discharge vent...
Good luck,
Andy
Good luck,
Andy
