Skytube's pipe condensation issue
Hello,
We've recently moved into a house that has one of those skylights (skytube) a dome on top of the roof and a sheet metal tube connected to a glass lens on our ceiling. We light the natural light that comes from it but we've noticed with this cold winter weather that the tube is condensating enough to collect drain mainly into the ceiling lens but it also is leaking in other areas since it's now leaking through the drywall ceiling.
How would we stop this from condensating? More insulation around the tube in the attic? Adding an exhaust fan to the somewhere on the tube and vent to the attic? Replacing the tube sheet metal tube with another type of reflective tubing?
Thanks
Thanks
Tube should have been insulated where it runs through the attic.
It's called a solar tube.
What room is this in?
What's the humidly level inside the house?
Lot's of things can cause this to happen.
Unvented gas fireplaces, no exhaust fan in a bathroom or not letting it run long enough after someone has used the shower, vent over a cooking stove not venting outside or it's not being used, crawl space with no vapor barrier.
ECT.
ECT.
location for the solar tube
Hello joecaption1,
The solar tube is located over our island in our kitchen. The stove and or sink isn't that close either. The current humidity in our house is 33%. There are no bathrooms within 50 feet of the solar tube. We've only been in this house since last October and it started leaking the first time when we really had a nasty cold spell and it just started up again after this subzero weather.
Do you think adding a fan will help or not do anything?
Thanks
Thanks
If any warm air from inside the house can leak into the tube or into the cavity around the tube where it can contact a cooler surface you will have condensation. These should be well sealed units as well as insulated as Joe said. Fiberglass insulation is an air filter and does not block air leakage.
Joe covered the other issue of too much humidity in the home.
Bud
Bud
Here's another thread on the same subject. Bud was the responder on that one also.
http://www.doityourself.com/forum/ro...k-i-think.html
