Sealing / Capping HVAC chase in attic
Old 02-19-15, 05:42 AM
T
Received 112 Upvotes on 100 Posts
I'm in the process of air sealing the attic. The HVAC chase from the basement into the attic is unsealed at that point and very warm air is entering the attic from the chase. Should I seal / cap the HVAC chase as I would the chimney, perhaps with sheet metal or should the chase remain open at the top - in the attic. Sealing it is consistent with my air sealing but I'm concerned about the very warm air being trapped in the chase.
Any suggestions?
Old 02-19-15, 01:50 PM
Received 4,117 Upvotes on 3,697 Posts
Seal the chase at the top.
The duct work is no warmer in your chase then in your walls and they're closed in.
Keep the heat you paid for in the house.
Old 02-19-15, 03:21 PM
B
Received 47 Upvotes on 43 Posts
Hi Tony,
Also seal and insulate all ducts up there. Any air that escapes from that chase, ducts, or other leaks has to be matched by an equal amount of air leaking back in, somewhere. Think of sealing as a double savings.
Bud
