static pressure
static pressure
I have a goodman 2.5 ton. I am trying to figure out the external static pressure. Goodman says it should be .2. I acquired a manometer. I hooked up two probes one to the return between the air filter and the a coil. The other to the supply side in the plenum above the a coil. The combined reading I get is .4 with air filter in and .2 with it out. Is this ok or do I need to enlarge the register opening. This is with a brand new filter
