Ventilation advice as I am confused
Hello,
I'm trying to see if the air pump being considered will deliver air thru a pipe. I've looked at the different calculations to do, did them and get answers I'm not clear how to assess.
But first what I'm trying to do: pump air thru a tube to vent a enclosed room. The tube is 20Meters long equivalent (it includes turns but have accounted for this with equivalent tube lengths). For simplicity sake lets assume sea level, 20degrees density at 1.2.
A pump yielding 330m3/hour of air is being considered with a duct tube of diameter 120mm with tube roughness at 0.04mm
My concern is the following math:
- my wind speed in the tube is 8.1 m/s
- calculated dynamic pressure at entry is 4.0 mmH20
- calculated dynamic pressure drop is 15.7 mmH20
So I conclude that the air will never reach the exit ?...
(this because the pressure drop is bigger than the entry pressure...
LOL, you are way beyond me, but I do enjoy math. A simple observation is, the wind speed you selected will not be achieved, thus the resulting pressure drop is way too high. The air will flow, but how much I can't say.
I'll let the hvac guys untangle the metric terms since they are better with air flow than I am.
Note, will that air flow increase the pressure within the space where it exits?
Bud
Bud
