Capping Duct
Capping Duct
I pretty much only work on kitchen ducts.
My son's bedroom furnace/AC register is only about 4' from the furnace.
The wife tried to seal it off with a magnetic cover. Poor to horrible results.
What's the best way to seal off the round duct in the attic? The duct is flexible insulated.
Are you talking about covering a return grill in the ceiling ?
If so..... you mentioned furnace.... how will that work if covered ?
I want to cut off supply to a wall register, both heat and AC. The room gets too cold with AC and too hot with heat.
I don't want to close off the register, I want to close off the round supply duct.
I don't know where's the best place to cut and cap it.
Near the plenum? Cut it midway, about 2' from furnace?
No dampers. Can I put one in-line with no condensation problems?
Simply trying to block the register with some kind of cover causes bad condensation at the register.
Received 38 Upvotes
Note well, a butterfly damper will be near maximum flow at about 60% open so adjustment is best in the range less than 60% open. Note also that noise level will increase as the damper is closed and this is more pronounced the closer the damper is to the outlet terminal.
