Air circulation unit in shop ?
Old 02-01-16, 12:33 PM
I have what looks like a fresh air circulation system in a shop there is a duct going down from the unit and one going outside I followed wires from it leading to the main heat exchanger unit where they were disconnected. I touched them together and the unit did not turn on is there something wrong with it. Does it even do anything? I will post pics of it and give more info.
Thanks
Old 02-01-16, 12:57 PM
Received 786 Upvotes on 689 Posts
Welcome to the forums!
Have you put a meter on the wires to see if they are live? Can you follow the wires back to the breaker box? pics could prove helpful - http://www.doityourself.com/forum/el...your-post.html
Old 02-01-16, 01:39 PM
I will take pictures later of my unit to show what it looks like. I will test the 18awg wire coming from the unit. Unless im supposed to test the 120VAC line.
Old 02-01-16, 02:27 PM
If the unit isn't hooked up testing it won't tell you if there is power, you need to find out if the supply wire is hot.
Old 02-02-16, 03:59 PM
The supply is hot. There is a transformer attached to the supply switch. I will try to get a picture of that and post later.
