Whole house fan motor replacement
Received 0 Votes
I'm trying to replace the motor. The following information is directly from the faceplate: GE 5KH3QPA0358X (model #), HP 1/3-1/9, V 115, PH 1 A 6.40/2.80, RPM 1725/1140, HZ 60, CONT, SF 1.0, AMB 40°C, CODE M, FP 48, THERMALLY PROTECTED CL A INS, CPA
Can anyone tell me if a replacement motor exists for the obsolete GE or is my only option, bringing it into a motor supply-type business for them to match up?
Received 0 Votes
Whole house fan motor replacement wiring confusion
I'm confused somewhat how to wire the new motor (Dayton 3K386); configured for CW or CCW rotation. The old motor was GE 5KH3QPA0358X; not configured for reverse rotation. I'm enclosing pictures of the old motor, consisting of 3 terminals, with wiring connected, & a picture of the new motor, consisting of 4 terminals, numbered 1-4, from right to left; terminal 4 has it's numerical designation behind the terminal, unlike the others. Also included are the old motor wiring (disconnected), wall timer (wiring connected), toggle switch wiring (disconnected), & Dayton 3K386 wiring label.
In the "old motor wiring" picture, the wiring harness (visibly marked 12/2) on the left is the "power in" source. The wiring harness on the right has a black lead originating at the timer & a white lead originating at the toggle switch low position. The black lead from the "power in" source is joined/bridged with the black lead which originates at the timer (as shown in the “old motor wiring” picture). Why are the two black leads joined? Does that make the white lead in the "old motor wiring" picture wiring harness (visibly marked 12/2) on the left, the "common" wire?
In the high-off-low toggle switch wiring picture, the "low speed" white lead on the right corresponds to the white lead of the "old motor wiring" picture from the wiring harness on the right. In the high-off-low toggle switch wiring picture, the "high speed" white lead on the left corresponds to the single black lead in the middle of the "old motor wiring" picture, whose color was changed for motor terminal connection differentiation purposes. In the high-off-low toggle switch wiring picture, the wire nut-secured wire at the bottom of the picture originates at the toggle switch off position & links to the timer.
Based on the attached Dayton 3K386 wiring label, can anyone provide motor wiring assistance?
The picture of the connection diagram is blurry. Can you post a better picture?
I see that you have 2 whites and a black. Do you know where each white went on the old motor? It doesn't look like you labeled either white wire.
Does the old motor have a connection diagram that you can post so that we can find High, Low, and neutral?
Is the control that you pulled off the wall functional? Are we going to use it?
Was the old motor spinning clockwise or counter clockwise? The fan blade will help you determine the rotation.
This post was made more complicated because you unwired other components and didn't put them back after determining high speed..
We still need to check rotation.
Received 0 Votes
Whole house fan motor replacement old & new wiring
I've attached pictures of the old GE motor's wiring configuration as well as the current wiring configuration of the new Dayton motor.
Please review the wiring drawings for accuracy. With all wiring attached to the new Dayton motor, the motor runs on 1(one) speed only. I replaced the 3-position (high-off-low) toggle switch as well as the high & low speed leads from the toggle switch to the motor, nevertheless, with the same result. If I reverse the terminal #1(high) & terminal #3(low) leads at the motor, the motor still runs at only 1(one) speed. After switching the leads at the motor, the only thing that changes is the position I have to flip the toggle switch in order for the motor to run.
Is it possible that I was sent a defective motor? If so, is there a way to bench test the motor to check the RPMs, rated at 1725 & 1140?
By the way, the current clockwise rotation is accurate.
I recolored your diagram slightly in order to follow it easier.
When the motor should be operating in low speed... you should measure 120vac on the #2 and #3 terminals.
When the motor should be operating on high speed... you should measure 120vac on the #1 and #2 terminals.
I'd imagine there may be a wiring issue in relation to the high/low switch.
To test motor.... follow instructions above or....
Connect neutral to terminal #2.
Power on terminal #1 will run the motor in high.
Power on terminal #3 will run the motor in low.
Received 0 Votes
To define the motor test specifically, what you're instructing me to do is to use the "power in" black & white leads to connect directly to the motor by removing any toggle switch related terminal leads attached to the motor terminals & connect the "power in" black lead to terminal #1 & the "power in" white lead to terminal #2 to check the motor's high speed as well as connect the "power in" black lead to terminal #3 & the "power in" white lead to terminal #2 to check the motor's low speed, correct? If the motor doesn't run with the "power in" black lead connected to either terminal #1 or #3 & the "power in" white lead connected to terminal #2, then there's a motor issue, correct?
Received 0 Votes
I bypassed the 3-position toggle switch & timer & connected the "power in" black lead to terminal #1, the motor functions. I then connected the "power in" black lead to terminal #3, the motor DOES NOT function. I've come to the conclusion that this motor is defective, do you agree?
